TwinTurbo.NET: Nissan 300ZX forum - ES in the rear control arms is a mess. Noisy. (n/m)
on December 13, 2018 at 10:55 AM
How are you squeaks and vibrations
posted by JerseyTex
on December 13, 2018 at 05:56 AM
Rear control arm bushings. Slip fit w/ bolt or some play?
Gordo NA2LS Daytona
12:35:09 12/12/18
I have no comment on the bolt fitment but I will say good
nissubaru
13:47:37 12/12/18
Re: I have no comment on the bolt fitment but I will say good
JerseyTex
14:02:14 12/12/18
ES Bushings here... (n/m)
Barry (NJ)
15:44:45 12/12/18
JerseyTex
05:56:30 12/13/18
Nothing objectionable...
Barry (NJ)
08:38:41 12/13/18
ES in the rear control arms is a mess. Noisy. (n/m) -
10:55:19 12/13/18
I imagine a ton of flex around the corners and thus squeaks
JerseyTex
12:40:49 12/13/18
The ES Bushings flex less than stock...
Barry (NJ)
13:35:00 12/14/18
Like Gordo you're getting older & hearing is shot. (n/m)
17:49:36 12/14/18
Rubber for street. These are the one's that Bernie cut out
Gordo NA2LS Daytona
16:09:56 12/12/18
I've got a shop that'll burn 'em out & cleanup the cups w/
Gordo NA2LS Daytona
16:16:04 12/12/18
Yes. Cut, drill, air chisel FTW
ConVerTT
19:09:36 12/12/18
I believe with OEM bushings the pivot occurs in the bushing
LitlElvis
14:01:39 12/12/18
Thanks LitlElvis... It makes sense that it would function
Gordo NA2LS Daytona
16:08:07 12/12/18
Correct (n/m)
01:30:12 12/13/18
The bolts don't really move inside the sleeve once torqued (n/m)
01:29:58 12/13/18
